SNMP Settings
nadeemr
Community Member
What standard SNMP configuration is required on all cisco routers and switches for the CiscoWorks.
miheg
Level 9
Level 9
It needs RO access to discover the devices.
For configuration management it either needs RW access or you should give ciscoworks a level 15 telnet/SSH access to the device.
The choice is yours.
Cheers,
Michel
