05-24-2018 05:46 PM - edited 03-01-2019 06:36 PM
For the past 2 weeks I've been dealing with an issue with my Nexus 5K. Once per hour (at the same time every hour), an SNMP Trap notification is sent to my NMS
On my N5K, I have the command "snmp-server enable traps config ccmCLIRunningConfigChanged"
The "show accounting log" does not show anything during the times the trap is sent. If I make a legitimate config change, that will send the trap (as expected) and shows in the accounting log.
Below is the trap I receive every hour. Any advice would be appreciated
sysUpTime:= 164 days 23 hours 54 minutes 56.42 seconds (1425569642)
snmpTrapOID:= CISCO-CONFIG-MAN-MIB:ccmCLIRunningConfigChanged (1.3.6.1.4.1.9.9.43.2.0.2)
ccmHistoryRunningLastChanged:= 164 days 23 hours 54 minutes 49.91 seconds (1425568991)
ccmHistoryEventTerminalType.493:= notApplicable(1) (1)
05-24-2018 10:59 PM
- Do you have Cisco Prime ? Some managerial actions by Prime, could lead to this trap , although they are not related to real config changes ?
M.
05-25-2018 06:25 AM
