SNMP Trap Configuration
dhalaska
Community Member
I would like to enable snmp traps on my CatOS and IOS switches. Specifically, I would like to receive notifications on the following:
Power supply failure
Line card failure on chassis
Uplink failures (regardless of interface type)
I understand I should use the command snmp-server enable traps IOS. If so, I see that power supply traps can be sent with the envmon keyword. I also see that interface traps can be sent with the SNMP keyword. Is this correct and can I configure that for specific interfaces and not all of the ports/interfaces on a device
How can the line card failure traps be configured and how can all these be setup on CATOS?
Thank you,
David
David Stanford
Hi David,
You are correct that you can limit interface traps on a per interface basis, this is available in most code. You can enter a command like:
NO SNMP-SERVER TRAP LINK-STATUS
or
This will tell the interface whether to generate linkUp/Down traps
Here's a couple of good links which show what traps are sent from the different snmp-server trap options in IOS and CatOS:
http://www.cisco.com/en/US/tech/tk648/tk362/technologies_tech_note09186a008021de3e.shtml
http://www.cisco.com/warp/public/477/SNMP/catos_traps.shtml
This is good. Thank you for the quick response.
I still don't see how to do module up/down traps on a Catalyst switch running IOS. Can it be done on IOS?
On my cat6K running IOS I could do:
Interface level:
no snmp trap link-status
or
Global to enable up/down traps:
snmp-server enable traps snmp
