SNMP trap for CPU and Temperature
k.ramalingam
What is the default threshold for CPU for switch (Cat 3570) and router (Cisco 2800) and Temperature values and can we alter it.
Joe Clarke
There is no temperature support on the 3750s. If you do a "show env temp status" you will see that those sensors are not present. For the 2800, the temperature threshold is 65 degrees Celsius. This cannot be changed.
