SNMP Trap notification trigger issue
rodrigo.magno
Community Member
Hey all, I need some help with the TCL scripting. I've deploying the TCL scripts to be triggered by an SNMP notification but they are not working; on the routers I have it installed on the TCL script doesn't kick off when it receives the trap.
Here is the script for receiving the trap:
::cisco::eem::event_register_snmp_notification oid 1.3.6.1.4.1.33333.2.0 oid_val "New NHC" op eq
namespace import ::cisco::eem::*
namespace import ::cisco::lib::*
array set arr_einfo [event_reqinfo]
set acl_ip {}
if [catch {cli_open} result] {
error $result $errorInfo
} else {
array set cli1 $result
if [catch {cli_exec $cli1(fd) "enable"} _cli_result] {
error $_cli_result $errorInfo
if {$_cerrno !=0} {
set result [format "component=%s; subsys err=%s; posix err=%s;\n%s"  $_cerr_sub_num $_cerr_sub_err $_cerr_posix_err $_cerr_str]
error $result
foreach snmp_item [array names arr_einfo 1_3_6_1_4_1_33333_3_0 ] {
if [catch {cli_exec $cli1(fd) "show access-list INBOUND | i $arr_einfo($snmp_item) "} _cli_result] {
set acl_data $_cli_result
foreach acl_line [split $acl_data "\n"] {
if [regexp {[0-9]+\.[0-9]+\.[0-9]+\.[0-9]+} $acl_line acl_ip] {
lappend acl_ip $acl_ip }
if { $acl_ip == {}} {
        if [catch {cli_exec $cli1(fd) "configure terminal"} _cli_result] {
        if [catch {cli_exec $cli1(fd) "ip access-list extended INBOUND"} _cli_result] {
        if [catch {cli_exec $cli1(fd) "no deny ip any any log"} _cli_result] {
        if [catch {cli_exec $cli1(fd) "permit ip host $arr_einfo($snmp_item) any"} _cli_result] {
        if [catch {cli_exec $cli1(fd) "deny ip any any log"} _cli_result] {
if [catch {cli_exec $cli1(fd) "end"} _cli_result] {
if [catch {cli_exec $cli1(fd) "write memory"} _cli_result] {
        action_syslog priority warning msg "Host $arr_einfo($snmp_item) added to the INBOUND access-list"
and the config on that router for SNMP:
snmp-server community ****** RO 23
snmp-server trap-source GigabitEthernet2
snmp-server manager
and the debug of it receiving the trap:
*Mar 3 12:33:33.736: SNMP: Packet received via UDP from 10.20.249.253 on Tunnel1
*Mar 3 12:33:33.736: SNMP: V2 Trap, reqid 3353, errstat 0, erridx 0
sysUpTime.0 = 287828652
snmpTrapOID.0 = enterprises.33333.1.0.1
enterprises.33333.2.0 = New NHC
enterprises.33333.3.0 = 60.199.50.34
I was finally able to test this locally, and it works for me.  I registered this policy on a 1941 running 15.5(2)T1:
::cisco::eem::event_register_snmp_notification oid 1.3.6.1.4.1.33333.2.0 oid_val 1234 op eq direction incoming
set acl_ip {}
} else {
if {$_cerrno !=0} {
    error $result
action_syslog msg "Executed policy successfully"
Then, I tested it using the net-snmp snmptrap command:
snmptrap -v 1 -c public pi-rsquared enterprises.33333.1 192.168.1.1 6 1 '' enterprises.33333.2.0 i 1234 enterprises.33333.3.0 a 60.199.50.34
And here's what I see:
Apr 11 12:49:23.261: SNMP: Packet received via UDP from 192.168.1.1 on Vlan1
Apr 11 12:49:23.261: SNMP: V1 Trap, ent enterprises.33333.1, addr 192.168.1.1, gentrap 6, spectrap 1
 enterprises.33333.2.0 = 1234
Apr 11 12:49:23.269:  dest ip addr= 192.168.1.39
Apr 11 12:49:23.269:  dest if_index = 14
Apr 11 12:49:23.853: %HA_EM-6-LOG: sn_trap_test.tcl: Executed policy successfully
What you might be seeing is a bug with trap reception on Tunnel interfaces.  Can you try sending the trap so that the device receives it on a non-tunnel interface?
8 Replies 8
Joe Clarke
There is a bug where EEM doesn't process v2 traps.  Make sure you send traps as v1 and it should trigger.
Thanks Joe for that, but still on luck 😞
*Mar 9 11:43:47.156: SNMP: Packet received via UDP from 10.20.249.253 on Tunnel1
*Mar 9 11:43:47.156: SNMP: V1 Trap, ent enterprises.33333.1, addr 10.20.249.253, gentrap 6, spectrap 1
I also had "debug event manager all" on and nothing happened at all.
Try changing your 2.0 OID to be an integer and match on the integer value.
Hey Joe, tried that, no change:
Insights_Tech_DMVPN_RT2#
*Mar 10 15:29:02.659: SNMP: Packet received via UDP from 10.20.249.253 on Tunnel1
*Mar 10 15:29:02.659: SNMP: V1 Trap, ent enterprises.33333.1, addr 10.20.249.253, gentrap 6, spectrap 1
I assumed you also updated your EEM Tcl policy and reregistered it?
If so, try adding "direction incoming" to the event registration line so that incoming traps are processed.
Hi, also didn't work. Here's the data:
deb event manager all
All possible Embedded Event Manager debugging has been turned on
bigd-dmvpn-rt2#
*Apr 1 13:12:26.630: SNMP: Packet received via UDP from 10.20.249.253 on Tunnel1
*Apr 1 13:12:26.630: SNMP: V1 Trap, ent enterprises.33333.1, addr 10.20.249.253, gentrap 6, spectrap 1
sh event manager policy registered
No. Class Type Event Type Trap Time Registered Name
1 script user snmp_notification Off Fri Apr 1 12:31:57 2016 receive_nhrp_trap.tcl
oid {1.3.6.1.4.1.33333.2.0} oid-val {1234} op eq direction incoming
nice 0 queue-priority normal maxrun 20.000 scheduler rp_primary Secu none
______________________
more bootflash:receive_nhrp_trap.tcl
set acl_ip {}
} else {
if {$_cerrno !=0} {
error $result
set acl_ip {}
} else {
if {$_cerrno !=0} {
    error $result
Ok, finally found the problem, it was really me. I had the community value wrong on the snmp trap I was sending. All is working now.
Rodrigo
