SNMP v3 for cisco devices
yeow28
we will be configuring snmp3 for doing monitoring using manage engine Opmanager.
what is the correct way to configure snmp on the cisco switch n routers.
we have cisco 2960 switch, cisco 1111 routers.
in the opmanager credentials, i see only the following fields
Does the configuration work for you?
BR
****Kindly rate all useful posts*****
5 Replies 5
DanielP211
Hello!
Your configuration will be as follows:
snmp-server group groupSNMP v3 auth
snmp-server group groupSNMP v3 priv
snmp-server user snmpv3USER groupSNMP v3 auth sha 256 PASSWORD-AUTH priv aes 128 PASSWORD-PRIV
Please change the user and password with your credentials. You can also add a access-list to the user or to the groups.
BR
Also note, the user/pass configuration for snmpv3 will not show up in the running/startup configuration. You can check it with show snmp user.
BR
do i need to add in the snmp server host ip address ?
is the group name/profile name case sensitive ?
Hello!
It is case sensitive, you do not need to add the host IP address. You can limit it better with ACL-s. Like this per user:
snmp-server user snmpv3USER groupSNMP v3 auth sha 256 PASSWORD-AUTH priv aes 128 PASSWORD-PRIV access ACCESS-LIST
Or per group:
snmp-server group groupSNMP v3 auth access ACCESS-LIST
snmp-server group groupSNMP v3 priv access ACCESS-LIST
BR
BR
