snmp v3 with LMS
clark white
Level 2
Level 2
Dears
I have read many post but still confused for snmp v3 configuration, can anybody route me to the clear explanation example for snmpv3 on 2960 switches.
Below is the configuration on switches for CS 3.2  but I see a ?? in device & credential page of the Common service what I shld enter in  privacy password
which snmp walk tool is best to test the snmp reachability to the switch
please correct the configs it they are wrong.
snmp-server group admin v3 auth write adminview write adminview
snmp-server user snmpuser admins v3 auth md5 cisco access 10
snmp-server view adminview internet included
2 Accepted Solutions
AFROJ AHMAD
Hi Clark,
attached is the text file with sample SNMPv3 config.
you can use NET-SNMP ,MIB browser or any other tool to test the credentials.
Your config also looks fine other than view , it should include ISO
Thanks-
Afroz
***Ratings Encourages Contributors ****
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
Nope,
SNMPV3 works with SNMP user and group only. No community string required
Thanks-
Afroz
11 Replies 11
AFROJ AHMAD
Hi Clark,
Thanks-
Afroz
Dear Afroz,
we don't require the below traps commands for snmp v3
snmp-server host 172.X.X.X informs version 3 auth snmpuser config-copy
Hi Clark,
snmp-server host  command is user to send the TRAPS to the NMS server. If you don't want to send the TRAPS to NMS server then it is not required.
Thanks-
Afroz
Dear Afroz,
very good document
in my common services 3.2 I see the device as ??? I think this device  WS-C2960XR-24PD-I is not supported
to which version I can upgrade CS, and RME to support the above model.
LMS is installed in windows server I want to do a snmpwalk to test the verification and configs are proper how can I do that???
thanks
Hi Clark,
LMS 3.2 is already end of support.
Upgrade to 4.x and hopefully they should work.
Supported device table for LMS 4.2::
http://www.cisco.com/c/en/us/td/docs/net_mgmt/ciscoworks_lan_management_solution/4-2/device_support/table/lms42sdt.html
You can download and Installed NET-SNMP tool on the service ,also the same thing you can to from LMS server from this directory
Open the command prompt go to below location:
NMSROOT/CSCOpx/objects/jt/bin
then test the SNMP WALK ::
NMSROOT\CSCopx\objects\jt\bin> snmpwalk -v3 -u testuser2 -l AuthPriv -a md5 -A cisco123 -x des -X cisco123 10.104.149.180 1.3.6.1.2.1.1.2
SNMPv2-MIB::sysObjectID.0 = OID: SNMPv2-SMI::enterprises.9.1.283
Hope it will help
Thanks-
Afroz
Dear afroz,
I have extracted the below from your config please confirm the below configuration are OK.
access-list 90 permit 10.10.10.10
snmp-server community xyz@2014 RW 90
snmp-server view myview iso included
snmp-server group cisconms v3 auth read myview write myview access 90
snmp-server user snmpuser cisconms v3 auth md5 cisco priv 3des cisco
thanks
Looks perfect  :)
Thanks-
Afroz
Dear Afroz,
little confusion,
for SNMP v3 do we still require a snmp string ??
Nope,
Thanks-
Afroz
thanks afroj,
+5 for you again,
I was having a doubt that's the reason I though I shld continue with this thread only.
so the required configs for snmpv3 on the cisco network devices are as below:
Please confirm.
correct  :)
