SNMP v3 with sha-256 Authentication
hhadorn
Hi there,
I have a customer running Catalyst WS-C2960+24TC-L with IOS Release 15.0(2)SE5.
He would like to run SNMP v3 with following:
snmp-server user snmpuser GROUP-RO v3 auth sha-256 xxxxx priv aes 256 yyyyy
unfortunately I am not able to find any configuration option for auth sha-256, only for auth sha. On the other side i can configure aes 256.
Ist auth sha-256 supported with the running IOS Release?
If yes, how do i have to configure it?
If not, please indicate the minimum release number, wher sha-256 for snmpv3 auth is supported
Thanks a lot
Heinz
Mark Malone
You cant configure the SHA option like that in SNMPv3 in Cisco switches anyway ,you only get 2 choices SHA or MD5 even on newer 9ks its the same , you have option aes 256 in priv section alright
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/snmp/configuration/xe-3se/3850/snmp-xe-3se-3850-book/nm-snmp-snmpv3.html
authPriv
MD5 or SHA
Data Encryption Standard (DES)
Provides authentication based on the HMAC-MD5 or HMAC-SHA algorithms. In addition to authentication, provides DES 56-bit encryption based on the Cipher Block Chaining (CBC)-DES (DES-56) standard.
m_pfeiler
Helpful !  Because of still using insecure obsoleted / depreciated  auth. meth. / algorithms I think I will consider in making purchasing decisions.
br
