SNMP weird problem
lawwm
Hi guys,
I am having weird problem on the network devices. Setup
WAN Router(E0/0 10.10.59.254)<-->Coreswitch(No Sup module)<-->Lan Router
Aslo, would appreciate if you could explain what does it mean for this?
"ipRouteEntry.7.207.107.68.64 = 172.28.59.254
ipRouteEntry.8.207.107.68.64 = 4"
debug snmp packet from LAN router)
ipRouteEntry.7.207.107.68.64 = 10.10.59.254
ipRouteEntry.2.207.107.68.64 = 1
ipRouteEntry.1.207.107.68.64 = 207.107.68.64
ipRouteEntry.11.207.107.68.64 = 255.255.255.240
I got the result below when i issue.
207.107.68.64 is the external ip. I have no idea why i got IpRouteEntry 207.107.68.64(external IP). Thank you
WM
nhabib
Level 9
Level 9
To get a better understanding of what these mib objects mean, you may use the following link:
http://jaguar.ir.miami.edu/~marcus/snmptrans.html
In the place of ipRouteEntry, use 1.3.6.1.2.1.4.21.1
Basically, look up the following MIB objects:
1.3.6.1.2.1.4.21.1.1
1.3.6.1.2.1.4.21.1.2
1.3.6.1.2.1.4.21.1.7
1.3.6.1.2.1.4.21.1.8
1.3.6.1.2.1.4.21.1.11
Thanks Nadim. Two quick follow-up questions:
I'm seeing the following output when I debug SNMP packets:
Nov 2 12:59:31: SNMP: Response, reqid 4982449, errstat 0, erridx 0
ipRouteEntry.7.172.28.252.72 = 172.28.59.254
ipRouteEntry.8.172.28.252.72 = 4
ipRouteEntry.2.172.28.252.72 = 1
ipRouteEntry.1.172.28.252.72 = 172.28.252.72
ipRouteEntry.11.172.28.252.72 = 255.255.255.248
Nov 2 12:59:31: SNMP: Packet sent via UDP to 158.33.63.2
Nov 2 12:59:31: SNMP: Packet received via UDP from 158.33.63.2 on Ethernet0
Nov 2 12:59:31: SNMP: Get-next request, reqid 4982454, errstat 0, erridx 0
ipRouteEntry.7.172.28.252.72 = NULL
ipRouteEntry.8.172.28.252.72 = NULL
ipRouteEntry.2.172.28.252.72 = NULL
ipRouteEntry.1.172.28.252.72 = NULL
ipRouteEntry.11.172.28.252.72 = NULL
1. Notice how the second GETNEXT request is for the same route but the value returns as NULL. This seems to repeat for the whole routing table (The GETNEXTs are being generated by NNM). Any ideas?
2. Are the IP route addresses after the variable address considered the instance value of the variable? For example, 1.3.6.1.2.1.4.21.1.1 is the variable address and 172.28.252.72 is the instance?
appreciate any feedback.
Get-next is coming in from the Network Management (NMS) application. This is the way SNMP works. The NMS send the requests with a value of NULL, and the agent fills in the blanks.
Yes, 172.28.252.72 is the instance.
Awesome. Thanks Nadim!
