SNMPSET command not working Nexus 7700
andy.lewis
I am trying to get issue CLI commands to running-config using the "snmpset" command.  The command below appears to take just fine, but the commands are not reflected in the running-config.  The SNMP RW string I'm using has vdc-admin rights, so I'm not sure why the commands do not take.  The command uses a config file (9.0.46.30) on the server I'm accessing the device with.  I don't think it's the command so much as there seems to be an issue with the device setup itself.  It's a Nexus sub-vdc.
Any help is greatly appreciated. I'm pulling my hair out.
snmpset -v2c -c ATT-DIMERW 9.0.46.30 .1.3.6.1.4.1.9.9.96.1.1.1.1.2.3194 i 1 .1.3.6.1.4.1.9.9.96.1.1.1.1.3.3194 i 1 .1.3.6.1.4.1.9.9.96.1.1.1.1.4.3194 i 4 .1.3.6.1.4.1.9.9.96.1.1.1.1.5.3194 a 135.89.52.249 .1.3.6.1.4.1.9.9.96.1.1.1.1.6.3194 s 9.0.46.30 .1.3.6.1.4.1.9.9.96.1.1.1.1.14.3194 i 4
Steve Burdick
I am having the same problem on Catalyst 3650 switches (IOS=cat3k_caa-universalk9.SPA.03.06.01.E.152-2.E1.bin). Any workaround/fix?
