SNMPv2 and MD5
richhill
Is it possible to use MD5 to encrypt SNMPv2 community strings? If so, how do I go about doing that?
minielsen
Level 2
Level 2
No, it requires SNMPv3.
10 Replies 10
drolemc
Level 6
Level 6
To enhance the security of SNMPv2, MD5 is used in some implementations to authenticate communications between an SNMP server and agent. MD5 provides you with data integrity, origin authentication and checks for timeliness. Further, SNMPv2 can use the data encryption standard (DES) for encrypting information. If supported, the configuration for this will be dependant on the devices you are using. You should refer to the documentation for the device you are working on.
minielsen
Level 2
Level 2
ahmedaboush105
*What is SNMPv2 authentication protocol ????
A. Community Strings
B. HMAC-MD5
C. HDMAC-SHA
plez someone help me?????
what's correct answer ???
Hi Ahmed,
SNMPv2 authentication protocol  >> is Community string only
Thanks-
Afroz
[Do rate the useful post]
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
Thank you very much Afroj
I can hardly express my gratitude .
regards.
Hi Ahmed,
Kindly rate the useful post..
Thanks-
hi everybody
i need help ???
what two commands with display the current ip address and basic layer 1 and 2 status
of an interface?
1.sh protocols
2.sh ip interface
3.sh controllers
4.sh running-config
which two characteristics describe the access layer of the hierchical network design model ?
1.layer 3 support
2. port security
3.redundant components
4.vlans
regards
If this is from some of the questionnaire, following are the answers:
of an interface?
2.sh ip interface
4.sh running-config
2. port security
4.vlans
-Thanks Vinod **Rating Encourages contributors, and its really free. **
Thankful and greatful vinod
thank u for ur interest
hi everybody
plez help me ?????
i have dout about this qus?
Which three approaches can be used while migrating from an IPv4 addressing scheme to an IPv6 scheme ?
A. static mapping of IPv4 address to IPv6 addresses
B. configuring IPv4 tunnels between IPv6 islands
C. use DHCPv6 to map IPv4 addresses to IPv6 addresses
D. use proxying and translation (NAT-PT) to translate IPv6 packets into IPv4 packets
E. configure IPv6 directly
F. enable dual-stack routing
