SNMPv3 user without group setting showing
arielechano
Why is it that when SNMPv3 user "TestV3-User" was added to my SNMPv3 implementation on my 6506 switch, the group/MD5/Emcryption settings are missing for this user (See "sh snmp user" output)???
router#sh snmp user
User name: TestV3-User
Engine ID: 80000009030000249706EFC0
storage-type: nonvolatile        active access-list: test
router#sh snmp group
groupname: ILMI                         security model:v1
readview :*ilmi                         writeview: *ilmi
notifyview: <no notifyview specified>
row status: active
groupname: ILMI                         security model:v2c
row status: active
groupname:TestV3                     security model:v3 priv
readview :v1default                     writeview: <no writeview specified>
notifyview: *tv.FFFFFFFF.FFFFFFFF.FFF
row status: active      access-list: test
Commands entered:
snmp-server group TestV3 v3 priv read v1default access test
snmp-server user TestV3-User TestV3 v3 auth sha <pw> priv des56 <pw> access test
snmp-server host 10.7.7.250 traps version 3 priv TestV3-User
Sh version output: (also - what IOS version at 12.2 for 6500 support AES encryption???)
"sup-bootdisk:/s72033-ipservicesk9_wan-mz.122-18.SXF17a.bin"
cisco WS-C6506-E (R7000) processor (revision 1.1) with 458720K/65536K bytes of memory.
Processor board ID SAL1252E3C6
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
SuperLAT software (copyright 1990 by Meridian Technology Corp).
X.25 software, Version 3.0.0.
Bridging software.
TN3270 Emulation software.
3 Virtual Ethernet/IEEE 802.3 interfaces
90 Gigabit Ethernet/IEEE 802.3 interfaces
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
Thanks in advance.
Vinod Arya
It works for me perfectly on my 65k. I used your configuration only :
snmp-server user TestV3-User TestV3 v3 auth sha test123 priv des test123 access test
Show Output are following  :
6500#show snmp group
groupname: TestV3                           security model:v3 priv
readview : v1default                        writeview:
notifyview:
# show snmp user
Engine ID: 80000009030000190640E1B8
Authentication Protocol: SHA
Privacy Protocol: DES
Group-name: TestV3
# Show version
Cisco IOS Software, s72033_rp Software (s72033_rp-ADVENTERPRISEK9_WAN-M), Versio
n 12.2(33)SXJ3, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Mon 16-Apr-12 16:12 by prod_rel_team
ROM: System Bootstrap, Version 12.2(14r)S9, RELEASE SOFTWARE (fc1)
NMS-WL-6500 uptime is 4 days, 9 hours, 24 minutes
Uptime for this control processor is 4 days, 9 hours, 25 minutes
Time since NMS-WL-6500 switched to active is 4 days, 9 hours, 24 minutes
System returned to ROM by  power cycle (SP by power on)
System restarted at 08:36:19 IST Wed Sep 5 2012
System image file is "disk1:s72033-adventerprisek9_wan-mz.122-33.SXJ3.bin"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C6509-E (R7000) processor (revision 1.5) with 458720K/65536K bytes of m
emory.
Processor board ID SMC1429004N
Last reset from power-on
10 Virtual Ethernet interfaces
73 Gigabit Ethernet interfaces
4 Ten Gigabit Ethernet interfaces
To see whta pric/auth a IOS version support using ? is best to see option. I guess if it doesnt gave any error it is supported.
Probably may want to remove the complete command using NO option and configue it back.
-Thanks
-Thanks Vinod **Rating Encourages contributors, and its really free. **
Thank you so much for the response. I think I will have to upgrade to 12.2(33) image which also supports 3des/AES encryption.
That will be good to be on a newer release. Please close the thread if the upgrade fixed the issue.
-Thanks
