ICMP Using Cisco Configuration Professional
rkulik512
I am trying to set up the router (881) using Cisco Configuration Professional, to allow ping reply's..I can not for the life of me figure it out.  Any ideas greatly appreciated..
Marvin Rhoads
By default the router will respond to pings.
Do you have IOS zone-based firewall turned on by chance? If so, I can reply with what you'd need to allow ping replies.
yes it is using IOS zone
You need to add icmp to the allowed traffic from "self to out-zone" (out-zone being the external interface. In the CCP GUI it will look something like this:
That translates to CLI configuration lines similar to the following (only directly relevant commands included here):
class-map type inspect match-any ccp-cls-icmp-access
match protocol icmp
match protocol tcp
match protocol udp
policy-map type inspect ccp-permit-icmpreply
class type inspect ccp-icmp-access
  inspect
class class-default
  pass
zone-pair security ccp-zp-self-out source self destination out-zone
service-policy type inspect ccp-permit-icmpreply
interface GigabitEthernet0/1
description  $FW_OUTSIDE$
zone-member security out-zone
hmmm thats what I have....any thoughts??
