SNMPv3
stesarova
I have trouble with SNMPv3 authentication of some switches.
I have tried all three types of authentication:
NoAuthNoPriv
AuthNoPriv
AuthPriv
All this variants are generated this error:
Error performing SNMP operation.
Does anybody know, what is possible to do against this problem?
Thank you
sarka
5 Replies 5
Marvin Rhoads
Could you give us some more information to understand your problem? The type of devices, their software release level and the pertinent section of the script for starters. Also, what tool are you using to access the switches via SNMP? If CiscoWorks, what version.
One common error that folks have been making lately is that they are not defining a context for SNMP. See the posting at http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Network%20Infrastructure&topic=Network%20Management&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.2cd2bbae/0#selected_message for more information.
I have tried to use to this purpose
application CiscoWorks LMS 3.1
The monitored devices are Cisco Catalyst 6509.
I will see the posted link.
Thank you very much
Sarka
Can you post a copy of your snmp v3 config?
snmp-server group GroupPriv v3 priv
snmp-server user UserPriv GroupPriv v3 auth md5 Cisco123! priv des56 Cisco123! access 95
User: UserPriv
Password: Cisco123! (authentization MD5)
PrivPassword: Cisco123! (encryption DES)
M.
Hi David,
One of the monitored devices is this type:
Cisco 2600,2800,3700,3800 Series 16-Port EtherSwitch Service Module
There is detailed list of configuration SNMP on monitored box:
snmp-server view readview internet included
snmp-server location Brno, Purkynova 101, 1 NP, serverovna
snmp-server contact unix@homecredit.net
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps tty
snmp-server enable traps dsp card-status
snmp-server enable traps flash insertion removal
snmp-server enable traps envmon
snmp-server enable traps config-copy
snmp-server enable traps entity
snmp-server enable traps event-manager
snmp-server enable traps ospf state-change
snmp-server enable traps ospf errors
snmp-server enable traps ospf retransmit
snmp-server enable traps ospf lsa
snmp-server enable traps ospf cisco-specific state-change nssa-trans-change
snmp-server enable traps ospf cisco-specific state-change shamlink interface-old
snmp-server enable traps ospf cisco-specific state-change shamlink neighbor
snmp-server enable traps ospf cisco-specific errors
snmp-server enable traps ospf cisco-specific retransmit
snmp-server enable traps ospf cisco-specific lsa
snmp-server enable traps cpu threshold
snmp-server enable traps syslog
snmp-server enable traps isakmp policy add
snmp-server enable traps isakmp policy delete
snmp-server enable traps isakmp tunnel start
snmp-server enable traps isakmp tunnel stop
snmp-server enable traps ipsec cryptomap add
snmp-server enable traps ipsec cryptomap delete
snmp-server enable traps ipsec cryptomap attach
snmp-server enable traps ipsec cryptomap detach
snmp-server enable traps ipsec tunnel start
snmp-server enable traps ipsec tunnel stop
snmp-server enable traps ipsec too-many-sas
snmp-server enable traps voice fallback poor-qov
snmp-server community ****** RO 95
snmp-server community ****** RW 98
snmp-server host 192.168.35.22 version 2c ******
snmp-server host 192.168.35.97 version 2c ******
If you have some idea where could be a problem, let me know, please.
Sarka
