Hi there,
Im trying to get the Qos dropped Packets from a Cisco 6800 Switch (image: s72033-ipservicesk9_wan-mz.122-33.SXJ5.bin) via snmpwalk.
I'm sure i use the right credentials and when i do "sh snmp mib" on the Switch, i see all the necessary Sub-IDs.
The exact OID i'm trying to get is 1.3.6.1.4.1.9.9.166.1.15.1.1.14 , Cisco SNMP Object Navigation says the MIB is being supported.
But still when i do snmpwalk the errormessage i get is:
SNMPv2-SMI::enterprises.9.9.166.1.15.1.1.14 = No Such Instance currently exists at this OID
snmpgetnext shows:
SNMPv2-SMI::enterprises.9.9.168.1.1.1.0 = INTEGER: 0
So im not sure what do now beacause the Webpage tells the OID is being supported and I see the SUB-IDs on the Switch, but i'm not able to get the OID through snmpwalk v3, do you guys have any hint, how i can get it? i'll appreciate any help.
Thanks in Advance
