SNMPWalk - retrieve UDLD status from multiple switches
kamil.swedrak
Hello everyone,
I'm walking through the case where I need check if UDLD is enabled on particular switch in the network.
The point is that I have mix environment (3560/3650/3750/3850) - so different OID for each switch.
I'm using Microsoft SNMPwalk to walked through all OIDs but cannot catch OID for UDLD.
I reviewed Cisco MIB for particular Cisco switch but it not giving me specific OID.
Dear Experts - please help, thank you.
Hello @kamil.swedrak
The best way to handle this is using a MIB Parser like Paessler MIB. Then you can find the MIB file, important and you´ll be able to see the OID:
https://sourceforge.net/p/netdisco/mibs/ci/1.5/tree/cisco/CISCO-UDLDP-MIB.my
For example. The OID for Global enable is 1.3.6.1.4.1.9.9.118.1.1.1.0
Interface enable 1.3.6.1.4.1.9.9.118.1.2.1.1.1
Interface Oper Status 1.3.6.1.4.1.9.9.118.1.2.1.1.2
etc,etc.
-If I helped you somehow, please, rate it as useful.-
