SNTP - Clock is unsynchronized
BigK
I configured SNTP on 2 remote sites exactly the same. They both able to reach the SNTP server( switch). I can ping and traceroute to sntp ip from both sites. Both sites reach the same ip in the 6th hop. Site 1 shows the correct day and time but site 2 does not. any help is appreciated.
Both sites are using Cisco SG350 with same firmware.
Site 1 #
clock timezone PST -8
clock summer-time PDT recurring usa
sntp server 10.10.x.2
Site 1#sho clock
 07:09:39 PDT  Jun 21 2019
Time source is sntp
Site 1 #sho sntp status
Clock is synchronized, stratum 2, reference is 10.10.x.2, unicast
Unicast servers:
Server : 10.10.x.2
Source : Static
Stratum : 2
Status : up
Site 1#traceroute ip 10.10.x.2
 1  10.22.x.25
 2  10.22.x.3
 3  x.x.x.x public IP
 4 x.x.x.x  public IP
 5  x.x.x.202 public IP
 6  10.10.x.5
Site 2#
Site 2 #sho clock
*17:09:30 PDT  Apr 15 2019
Time source is sntp
Site 2 #show sntp status
Unicast servers:
Server : 10.10.x.2
Source : Static
Stratum : 255
Status : down
Site 2#traceroute ip 10.10.x.2
 1  10.30.x.25
 2  10.30.x.2
 3  x.x.x.x  public IP
 4  x.x.x.x  public IP
 6  10.10.x.5
Thanks for the reply. Issue has been resolved. After carefully going trough the config. I found out that applying the source interface for sntp helped resolved the issue.
Mark Elsen
 https://www.cisco.com/c/en/us/support/docs/ip/network-time-protocol-ntp/116161-trouble-ntp-00.html
 M.
Only two commands are available on SG350
Site 1 #sho sntp
configuration    --> Show the configuration of the Simple Network Time Protocol (SNTP)
status             -->To show the status of the Simple Network Time Protocol (SNTP)
It is sort of helpful to know that you do have IP connectivity for both switches to the sntp server (both can traceroute). The symptoms suggest that something is interfering with sntp from site 2. Is it possible that something along the path to the server (perhaps a firewall or something like that) has a security policy that is not allowing sntp traffic?
Rick
Rick
