SPAN and RSPAN on same destination?
TobiW.94
I have an physical analyzer-device which collects the mirrored datatraffic in my network and analyzes it.
The analyzer is connected to my coreswitch from which i want to read the data traffic via SPAN.
But I also want to send the data traffic of my access switches via the core switch to the appliance using RSPAN.
It seems, that the destination interface from SPAN and RSPAN cannot be the same.
My analyzer is connected with just one cable to read the mirrored traffic.
Is there any way to configure the SPAN / RSPAN to read both the "local" traffic from the core switch and the traffic from the connected access switches?
Thank you very much!
TobiW.94
Mark Elsen
                    - FYI : https://community.cisco.com/t5/switching/combining-span-and-rspan/td-p/2329000
  The general principle with RSPAN is that you do not attach any devices you want to monitor to the device of the destination port. You can only use SPAN for this. You cannot mix both as you can only use one destination port per session.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
