01-17-2018 04:05 PM - edited 03-01-2019 06:21 PM
Hello Cisco Community:
I have the following configuration done in the ASA5525X but only works communication between OPC Server <-> PCN and OPC Server <-> Enterprise Network.
I need communication between RESS Server <-> RAP and RESS Server <-> PCN.
Also I attached the architecture.
Who could give a hand with this case? Thank you for your help!
ASA Version 9.1(2)
hostname ciscoasa
domain-name redpropia.wan
enable password klBsA9baYC2Y4G8z encrypted
passwd klBsA9baYC2Y4G8z encrypted
names
interface GigabitEthernet0/0
nameif Corporativa
security-level 0
ip address 192.168.1.198 255.255.255.0
interface GigabitEthernet0/1
nameif DMZ
security-level 50
ip address 192.168.50.1 255.255.255.0
interface GigabitEthernet0/2
nameif Control
security-level 100
ip address 192.168.100.100 255.255.255.0
interface GigabitEthernet0/3
nameif RESS
security-level 50
ip address 192.168.60.1 255.255.255.0
interface GigabitEthernet0/4
description RAP
no nameif
no security-level
no ip address
interface GigabitEthernet0/4.1
vlan 1
nameif vlan1
security-level 50
ip address 192.168.51.2 255.255.255.0
interface GigabitEthernet0/5
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/6
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/7
shutdown
no nameif
no security-level
no ip address
interface Management0/0
management-only
nameif management
security-level 100
ip address 192.168.2.1 255.255.255.0
boot system disk0:/asa912-smp-k8.bin
ftp mode passive
dns server-group DefaultDNS
object network EstacionOPC
host 192.168.50.3
object network ServerA
host 192.168.100.3
object network ServerB
host 192.168.100.5
object network RESS_SERVIDOR
host 192.168.60.2
object-group network ClientesCorporativos
network-object 192.168.1.0 255.255.255.0
object-group network OPC
network-object object EstacionOPC
object-group network ServidoresExperion
network-object object ServerA
network-object object ServerB
object-group service Corporativo-OPC tcp
port-object eq 3389
object-group service OPC-Control tcp
port-object eq 21379
object-group service Microsoft_DS tcp
port-object eq 445
object-group service PORT1 udp
port-object eq 12321
object-group service HONEYWEEL tcp
port-object eq 1433
port-object eq 3389
port-object eq 55550
port-object eq 55556
port-object eq 55557
port-object eq 55563
access-list DMZ_access_in extended permit tcp object-group OPC object-group ServidoresExperion eq 21379
access-list DMZ_access_in extended permit icmp object-group OPC object-group ClientesCorporativos
access-list DMZ_access_in extended permit icmp object-group OPC object-group ServidoresExperion
access-list DMZ_access_in extended deny ip any any
access-list Control_access_in extended permit tcp object-group ServidoresExperion object-group OPC eq 21379
access-list Control_access_in extended permit icmp object-group ServidoresExperion object-group OPC
access-list Control_access_in extended deny ip any any
access-list Control_access_in extended permit icmp object-group ServidoresExperion object RESS_SERVIDOR
access-list Control_access_in extended permit udp object-group ServidoresExperion object RESS_SERVIDOR object-group PORT1
access-list Control_access_in extended permit tcp object-group ServidoresExperion object RESS_SERVIDOR object-group HONEYWEEL
access-list Corporativa_access_in extended permit tcp object-group ClientesCorporativos object-group OPC eq 3389
access-list Corporativa_access_in extended permit icmp object-group ClientesCorporativos object-group OPC
access-list Corporativa_access_in extended permit tcp object-group ClientesCorporativos object-group OPC eq ftp
access-list Corporativa_access_in extended deny ip any any
access-list RESS_access_in extended permit icmp object RESS_SERVIDOR object-group ServidoresExperion
access-list RESS_access_in extended permit tcp object RESS_SERVIDOR object-group ServidoresExperion object-group HONEYWEEL
access-list RESS_access_in extended permit udp object RESS_SERVIDOR object-group ServidoresExperion object-group PORT1
pager lines 24
logging asdm informational
mtu Corporativa 1500
mtu DMZ 1500
mtu Control 1500
mtu management 1500
mtu RESS 1500
mtu vlan1 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-713.bin
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
nat (Corporativa,DMZ) source static any any destination static interface EstacionOPC no-proxy-arp
nat (Control,RESS) source static any any destination static interface RESS_SERVIDOR no-proxy-arp
nat (RESS,Control) source static any any destination static interface ServidoresExperion no-proxy-arp
access-group Corporativa_access_in in interface Corporativa
access-group DMZ_access_in in interface DMZ
access-group Control_access_in in interface Control
access-group RESS_access_in in interface RESS
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
http server enable
http 192.168.2.0 255.255.255.0 management
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
crypto ipsec security-association pmtu-aging infinite
crypto ca trustpool policy
telnet timeout 5
ssh timeout 5
ssh key-exchange group dh-group1-sha1
console timeout 0
dhcpd address 192.168.2.2-192.168.2.254 management
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
ssl encryption rc4-sha1 aes128-sha1 aes256-sha1 3des-sha1
username Admin password .i8epuOKKyFaR9jH encrypted privilege 15
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum client auto
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect ip-options
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
Cryptochecksum:a3b8b61829eb3e8eaef54e030ace4e10
: end
