Specify IOS storage destination using Ciscoworks RME Software Distribution
ethanm.so
Hello all,
   I'm trying to plan a mass ios upgrade to switches in our network using ciscoworks rme software distribution.  I've tested all distribution method(by devides[basic,advnaced], image, remote staging) but it seems like I cannot really specify where the exact location of IOS image to be stored in switches.  What I would like to do is store the ios image in flash:/directory rather than flash: .....  Any inputs will be helpful.  Thank you.
Joe Clarke
You cannot do this.  SWIM will always put images into the root of the specified flash file system (unless the image is a tar file for a
desktop switch).
