ssh login issues
dupemakss
Community Member
Hello All,
can someone help me out on this issue, i configured SSH on several devices in my office and some remote location only to find out that
some of the devices can allow me log on successfully while others gives me this error
"Access denied
Using keyboard-interactive authentication."
below is my ssh config:
conf t
ip domain-name lycotech.nl
username admin privilege 15 password 0 cIsc00
crypto key generate rsa
1024
ip ssh vers 2
line vty 0 15
transport input ssh
do wr
end
please help ASAP
Vinod Arya
Ideally you should post this question on Lan switching and routing community here :
https://supportforums.cisco.com/community/6016/lan-switching-and-routing
Some of the issues I can think of is :
> Check you password lenght, as some old devices may have issue with smaller one.
> Which tool/application are you using for SSH? Try a different tool or newer version or same - Putty, secure crt, OpenSSH or if any Unix/Linux Server.
>Are those devices configured for AAA which are not working? Are these SSH credentials correct as per AAA?
You can check these things and confirm if nothing is from this.
-Thanks
Vinod
**Encourage contributors. RATE them**
-Thanks Vinod **Rating Encourages contributors, and its really free. **
