SSH LOGIN LOCAL ISSUE
Thomas7450
Visitor
Hi all I am having trouble with my SSH lab. I have been able to SSH my switch when just setting a password for the vty lines and using the login command. However when i opt to use the login local command and ask for the vty line to grab the credentials of the username and password set in global config I am unable to login. Please can some tell me if there is anything obviously wrong with the below config..its starting to stress me out now..there is nothing fancy going on I have just used my default vlan 1 as the vlan with the ip address.
anders(config-if)#do sh start
Using 742 bytes
version 12.1
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname anders
clock timezone bst 0
ip domain-name cisco.com
username thomas privilege 15 password 0 anders
spanning-tree mode pvst
interface FastEthernet0/1
interface FastEthernet1/1
interface FastEthernet2/1
switchport mode access
interface FastEthernet3/1
interface FastEthernet4/1
interface FastEthernet5/1
interface Vlan1
ip address 192.168.1.253 255.255.255.0
ip default-gateway 192.168.1.254
banner motd ^Chelp me^C
line con 0
line vty 0 4
login local
transport input ssh
line vty 5 15
login local
transport input ssh
5 Replies 5
Francesco Molino
Are you getting the login prompt?
Just out of curiosity, have you removed the crypto key before pasting the config? Because i don't see it.
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Hi thanks for your reply, yeah the crypto keys have been generated at 512. I have just gon over all the same config again from scratch and issue still remains...I was not aware that the keys should be noted in the sh start menu...I have checked tho and definately there as when i go to enter crypto ken gen rsa i am greeted with a message teeling me there already enabled..if you look at the command after show run you will see what I mean. Any thoughts at all? Thanks
User Access Verification
Username: tom
Password:
swtich#en
swtich#conf t
Enter configuration commands, one per line. End with CNTL/Z.
swtich(config)#cry
swtich(config)#crypto k
swtich(config)#crypto key ge
swtich(config)#crypto key generate rsa
% You already have RSA keys defined named swtich.cisco .
% Do you really want to replace them? [yes/no]: n
swtich(config)#do sh run
Building configuration...
Current configuration : 1384 bytes
version 12.2
hostname swtich
enable secret 5 $1$mERr$hx5rVt7rPNoS4wqbXKX7m0
ip ssh version 1
username tom privilege 15 password 0 cisco
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
switchport mode trunk
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
no ip address
shutdown
interface Vlan2
mac-address 0090.0c66.8101
ip address 10.1.2.1 255.255.255.0
ip default-gateway 10.1.2.254
line con 0
login local
Are you getting the prompt? What is your error message?
you can add :
aaa new-model
aaa authentication login default local
This will configure default aaa authentication to be local and under lines just configure it as login
Francesco
Hi, I am not familiar with the AAA comnands..the switch does not seem to
recognise these commands in global config mode..I have e set the vty lines
to login local so would have thought that would be enough ..I'm lost
really am..starting to think it's a packet tracer glitch but could most
likely be me missing one small detail
Using login local needs only to have a username setup and that's the case on your side.
You're not answering my question: do you get the router prompt when ssh to it?
You can run a debug ssh on your router, try to ssh to it and paste the debug output.
Francesco
