SSL on WLC
Dima Dvorcovoy
I need to install our local certificates on our WLC. Failed.
>> https://www.sslsupportdesk.com/cisco-wireless-lan-controller-ssl-installation/# >>https://pvoord.wordpress.com/2012/06/20/importing-3rd-party-certificate-on-cisco-wlc/
>>https://support.quovadisglobal.com/kb/a476/how-do-i-install-a-certificate-onto-cisco-wlan-controller-wlc.aspx
I tried everything from advices above: installed openssl 0.9.8 and did all steps on it (of course, medial certificates are from 1.1).
== wifi.conf ==
[ req ]
default_bits = 2048
default_md = sha512
default_keyfile = wifi.key
prompt = no
encrypt_key = no
distinguished_name = DN
req_extensions = v3_req
[ DN ]
countryName = "BY"
stateOrProvinceName = "xxxx"
localityName = "xxxx"
postalCode = "nnnn"
streetAddress = "aaaa"
organizationName = "aaaa"
organizationalUnitName = "aaaaaaaaaaaaa"
commonName = "*.wifi.xxx"
emailAddress = "email@xxx.by"
[ v3_req ]
subjectAltName = DNS:wifi-a.wifi.xxx,DNS:wifi-b.wifi.xxx,DNS:wifi-c.wifi.xxx,IP:10.0.0.9,IP:10.0.0.10,IP:10.0.0.11
Command:
#openssl req -new -config wifi.conf -out wifi.csr
send csr for subscrition >>wifi.cer
#cat wifi.cer ../subca.cer ../rootcert.cer >all.cer
#openssl pkcs12 -export -inkey wifi.key -in all.cer -out wifi.pfx -clcerts -passout "pass:---"
#openssl pkcs12 -in wifi.pfx -out wifi.pem -passin "pass:---" -passout "pass:---"
# telnet wism
wism>transfer
wism transfer> download mode tftp
wism transfer> download datatype webauthcert
wism transfer> download serverip 10.0.0.66
wism transfer> download path /
wism transfer> download filename wifi.pem
wism transfer> download certpassword ---
wism transfer> download start
But I still got an error. What and where to check?
0 Replies 0
