SSO in NXOS and IOS
Rem Markov
Hey Everyone!
So I really want to get rid of the TACACS+ we have and set a SSO or some kind of token authentication.
Now I know that it might be impossible or hard, but I hope I'm wrong.
Is there someone here who has any idea how can this be implanted?
5 Replies 5
pieterh
removed, was not correct
What do you mean?  what was removed?
I think it should have been clear ?
I posted something, but the information was not the answer to your question
I cannot remove the post, only edit the content so I edited it to "removed, was not correct"
SSO token for device, I first time I heard about this.
SSO use for Remote Access VPN not for device.
can I know why you are looking for this auth ?
Is it possible to access a switch with a token rather then a default login with username and password.
Lets say like the vault?
