stack vs HA for switches
petercinvest
Level 4
Level 4
for access switches, does it make sense to stack? if we stack the switch, what's the difference between stacked switch and HA (active/passive) solution when one switch is down?
Marvin Rhoads
I can't say I've ever seen an active / passive access switch design.
Stacking is a generally accepted practice. It provides benefit of a single control plane and, depending on the model, potential benefit of things like StackPower which keeps a member switch up even if a power supply fails.
Either way, when a switch (or member switch in a stack) is down, anything plugged solely into that switch will also be offline.
