Bookmark
Subscribe
3534
Start/Stop System-Defined jobs
I am running into an issue where System-Defined SAM_Poller Jobs are running over 5 days. Since these jobs are "stuck", the CPU Usage of the Prime Infrastructure has been increasing gradually.
How can stop system-defined jobs? This seems not possible via the GUI. I was also not able to find any related settings referring these jobs. Usually these jobs run 10-20 seconds.
Attached is a screenshot of the Job Dashboads
Best regards,
Tim
AFROJ AHMAD
Hi Tim,
Did you tried from here :
Admin > Jobs Dashboard > System Defined ?
if above did not helped  then use the CLI option::
1. Make note of the job ID's that you want to delete.
2. Open a dos shell and go to NMSROOT\CSCOpx\bin  for e.g  C:\Progra~1\CSCOpx\bin
3. Issue the command:
cwjava -cw NMSROOT com.cisco.nm.cmf.jrm.jobcli
change NMSROOT to actual NMSROOT in the above command
3. It will take you to the Job CLI mode
4. Issue the command:
delete 1700 (the job ID you cannot delete).
5. Close all CiscoWorks browsers and issue the commands:
net stop crmdmgtd
net start crmdmgtd
6. Wait 15 minutes and log back in to CiscoWorks
Thanks-
Afroz
***Ratings Encourages Contributors ****
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
Hi Afroz,
thanks for the suggestion.
I forgot to mention this is Prime Infrastructure 2.1
Best regards,
Tim
after performing a ncs stop -> ncs start the the CPU load ist back to normal.
Still it would be helpful to know how to cancel/top/restart system-defined Jobs in Prime Infrastructure as going with a ncs stop/ncs start is very time-consuming.
Hoping to hear back from you.
Best regards,
Tim
Is there anybody found other way to interrupt system defined Job in Cisco PI?
Doing STOP/START Prime services is consuming time and impact monitoring.
