Here are the status codes:
CLDot11ClientStatus ::= TEXTUAL-CONVENTION
STATUS current
DESCRIPTION
"This textual convention defines the states
of an 802.11 client.
The semantics are as follows:
idle(1) - client is in idle mode.
aaaPending(2) - client's authentication is pending.
Request has been sent to AAA server for authentication.
authenticated(3) - client has been authenticated.
associated(4) - client is associated, but not
authenticated.
powersave(5) - client is in powersave mode.
disassociated(6) - client has dissociated and not in
any of the 802.11 networks managed by the controller.
tobedeleted(7) - client is marked for deletion.
probing(8) - state before association. The client
will be removed if it does not associate.
excluded(9) - client has been marked as excluded after fixed
number of authentication failures."
HTH,
Dan
