Stopping NTP
khuysmans
One of my Catalyst 3500XL switches is being quite resilient with NTP. I can see it trying to contact the wrong NTP server on my firewall. I have already changed the NTP server to something else and when I then check the status "show ntp status", it shows as synchronized with the newly added server.
Currently I have removed all ntp servers from the config, but it is still trying to connect to that given server via ntp-udp.
What am I overlooking here? Is there a way to restart the ntp service?
kind regards,
Kevin
Richard Burts
Kevin
The only way that I know to restart the NTP service is to reboot the router. It should be possible to fix the problem without resorting to a reboot of the router. If you would post the config of the 3500 perhaps we could find something that is causing these symptoms and suggest a solution.
Rick
Rick
Thanks Rick,
The config of my switch:
Current configuration:
! Last configuration change at 17:33:09 CET Wed Jan 25 2006 by kevin
! NVRAM config last updated at 17:33:15 CET Wed Jan 25 2006 by kevin
version 12.0
no service pad
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
service password-encryption
hostname SATENR7
enable secret 5
username kevin
clock timezone CET 1
clock summer-time CETst recurring last Sun Mar 2:00 last Sun Oct 3:00
ip subnet-zero
no ip domain-lookup
interface FastEthernet0/1
switchport access vlan 10
spanning-tree portfast
interface FastEthernet0/48
interface GigabitEthernet0/1
switchport mode trunk
interface GigabitEthernet0/2
interface VLAN1
no ip address
no ip redirects
no ip directed-broadcast
no ip proxy-arp
no ip route-cache
shutdown
interface VLAN10
ip address 192.168.1.7 255.255.255.0
no ip redirects
no ip proxy-arp
no ip route-cache
ip default-gateway 192.168.1.250
access-list 2 permit 192.168.1.49
snmp-server engineID local xxxx
snmp-server community public RO 2
line con 0
login local
transport input none
stopbits 1
line vty 0 4
password
login local
line vty 5 15
password
login local
end
Thanks for posting the config. There is certainly not anything in this config that would seem to cause NTP activity. Would it be possible to post the output of show ntp association detail?
It might also be helpful to see output from debug ntp events or debug ntp packet.
Rick
Rick
kka
Level 5
Level 5
Not sure this works in IOS 12.0, but you could try
"no ntp" in global config mode. This should stop
the NTP process.
