storm-control info via snmp ?
aeggers
hello,
is it possible to get information about storm-control "TotalSuppDiscards" via snmp ?
There is a CISCO-PORT-STORM-CONTROL-MIB available but not for Cat6k.
I would like to see if the configured value is exceeded.
Thaks in advance
andré
wong34539
Level 6
Level 6
I don't think storm control feature can be enabled and trap generated on a Catalyst 6K. But this can be achieved on a Catalyst 4500 switch. Have a look at the following documents which explain the Storm control feature in detail and also the steps to configure the same. This applies to catalyst 4500 switch and 3550 switches.
http://www.cisco.com/en/US/products/hw/switches/ps646/products_configuration_guide_chapter09186a00801a6b2c.html
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat4000/12_1_19/config/bcastsup.htm#1026643
