STP Bandwidth Rules
Snifferson
Community Member
Hi All,
Can anyone tell me:
I have 2 (a and b) redundancies. (a) goes through 1x 100baseT switch and (b) through 2x 1000baseT and 1x10baseT switches.
Will STP choose route a or b?
Effectively, I am asking, will STP choose the lowest average or does it do it a different way?
Joe
Michel Hegeraat
Level 11
Level 11
If you want to know how STP or RSTP works then google and wikipedia are your friends
Check out this page
http://en.wikipedia.org/wiki/Spanning_Tree_Protocol
Determine the least cost paths to the root bridge.
The computed  spanning tree has the property that messages from any connected device  to the root bridge traverse a least cost path, i.e., a path from the  device to the root that has minimum cost among all paths from the device  to the root. The cost of traversing a path is the sum of the costs of  the segments on the path.
The table below shows the default cost of an interface for a given data rate.
Data rate STP Cost (802.1D-1998) RSTP Cost (802.1W-2001)
4 Mbit/s2505,000,000
10 Mbit/s1002,000,000
16 Mbit/s621,250,000
100 Mbit/s19200,000
1 Gbit/s420,000
2 Gbit/s310,000
10 Gbit/s22,000
So in your case cost of a is: 19 and cost of b is: 2 x 4  + 100
Cheers,
Michel
...what Michel said (assuming the root bridge is reachable using BPDUs up both paths).
