Sup720 FIB TCAM Usage Monitor
rwill0ncgov
I searched around and saw examples of using expression mib and eem. But is there not a simple mib to poll for the equivalent of ? :
 FIB TCAM usage:                     Total        Used       %Used
 72 bits (IPv4, MPLS, EoM)     786432      516031         66%
that comes from the command:
#sh platform hardware capacity forwarding
I'm interested in collecting the "total", "used" and "%used" values over time.
I'd rather not add a script and I'm concerned about using expression mib to count half a million entries (should I be?).
I also looked at the CISCO-SWITCH-ENGINE-MIB and pulled:
"Name","Instance","Value","Type","Object ID"
"cseTcamResourceDescr","4021.1","Security Acl Mask Tcam Usage on module 7","Octet String","1.3.6.1.4.1.9.9.97.1.9.1.1.2"
"cseTcamResourceDescr","4021.2","Security Acl Value Tcam Usage on module 7","Octet String","1.3.6.1.4.1.9.9.97.1.9.1.1.2"
"cseTcamResourceDescr","4021.5","Qos Acl Mask Tcam Usage on module 7","Octet String","1.3.6.1.4.1.9.9.97.1.9.1.1.2"
"cseTcamResourceDescr","4021.6","Qos Acl Value Tcam Usage on module 7","Octet String","1.3.6.1.4.1.9.9.97.1.9.1.1.2"
"cseTcamResourceDescr","4021.9","Layer 4 Port Operator Tcam Usage on module 7","Octet String","1.3.6.1.4.1.9.9.97.1.9.1.1.2"
"cseTcamResourceDescr","4021.10","Inteface Mapping Tcam Usage on module 7","Octet String","1.3.6.1.4.1.9.9.97.1.9.1.1.2"
"cseTcamResourceDescr","5021.1","Security Acl Mask Tcam Usage on module 8","Octet String","1.3.6.1.4.1.9.9.97.1.9.1.1.2"
"cseTcamResourceDescr","5021.2","Security Acl Value Tcam Usage on module 8","Octet String","1.3.6.1.4.1.9.9.97.1.9.1.1.2"
"cseTcamResourceDescr","5021.5","Qos Acl Mask Tcam Usage on module 8","Octet String","1.3.6.1.4.1.9.9.97.1.9.1.1.2"
"cseTcamResourceDescr","5021.6","Qos Acl Value Tcam Usage on module 8","Octet String","1.3.6.1.4.1.9.9.97.1.9.1.1.2"
"cseTcamResourceDescr","5021.9","Layer 4 Port Operator Tcam Usage on module 8","Octet String","1.3.6.1.4.1.9.9.97.1.9.1.1.2"
"cseTcamResourceDescr","5021.10","Inteface Mapping Tcam Usage on module 8","Octet String","1.3.6.1.4.1.9.9.97.1.9.1.1.2"
"cseTcamResourceDescr","7008.1","Security Acl Mask Tcam Usage on module 10","Octet String","1.3.6.1.4.1.9.9.97.1.9.1.1.2"
"cseTcamResourceDescr","7008.2","Security Acl Value Tcam Usage on module 10","Octet String","1.3.6.1.4.1.9.9.97.1.9.1.1.2"
"cseTcamResourceDescr","7008.5","Qos Acl Mask Tcam Usage on module 10","Octet String","1.3.6.1.4.1.9.9.97.1.9.1.1.2"
"cseTcamResourceDescr","7008.6","Qos Acl Value Tcam Usage on module 10","Octet String","1.3.6.1.4.1.9.9.97.1.9.1.1.2"
"cseTcamResourceDescr","7008.9","Layer 4 Port Operator Tcam Usage on module 10","Octet String","1.3.6.1.4.1.9.9.97.1.9.1.1.2"
"cseTcamResourceDescr","7008.10","Inteface Mapping Tcam Usage on module 10","Octet String","1.3.6.1.4.1.9.9.97.1.9.1.1.2"
"cseTcamResourceDescr","8006.1","Security Acl Mask Tcam Usage on module 11","Octet String","1.3.6.1.4.1.9.9.97.1.9.1.1.2"
"cseTcamResourceDescr","8006.2","Security Acl Value Tcam Usage on module 11","Octet String","1.3.6.1.4.1.9.9.97.1.9.1.1.2"
"cseTcamResourceDescr","8006.5","Qos Acl Mask Tcam Usage on module 11","Octet String","1.3.6.1.4.1.9.9.97.1.9.1.1.2"
"cseTcamResourceDescr","8006.6","Qos Acl Value Tcam Usage on module 11","Octet String","1.3.6.1.4.1.9.9.97.1.9.1.1.2"
"cseTcamResourceDescr","8006.9","Layer 4 Port Operator Tcam Usage on module 11","Octet String","1.3.6.1.4.1.9.9.97.1.9.1.1.2"
"cseTcamResourceDescr","8006.10","Inteface Mapping Tcam Usage on module 11","Octet String","1.3.6.1.4.1.9.9.97.1.9.1.1.2"
"cseTcamResourceDescr","9010.1","Security Acl Mask Tcam Usage on module 13","Octet String","1.3.6.1.4.1.9.9.97.1.9.1.1.2"
"cseTcamResourceDescr","9010.2","Security Acl Value Tcam Usage on module 13","Octet String","1.3.6.1.4.1.9.9.97.1.9.1.1.2"
"cseTcamResourceDescr","9010.5","Qos Acl Mask Tcam Usage on module 13","Octet String","1.3.6.1.4.1.9.9.97.1.9.1.1.2"
"cseTcamResourceDescr","9010.6","Qos Acl Value Tcam Usage on module 13","Octet String","1.3.6.1.4.1.9.9.97.1.9.1.1.2"
"cseTcamResourceDescr","9010.9","Layer 4 Port Operator Tcam Usage on module 13","Octet String","1.3.6.1.4.1.9.9.97.1.9.1.1.2"
"cseTcamResourceDescr","9010.10","Inteface Mapping Tcam Usage on module 13","Octet String","1.3.6.1.4.1.9.9.97.1.9.1.1.2"
"cseTcamResourceUsed","4021.1","13","Gauge","1.3.6.1.4.1.9.9.97.1.9.1.1.3"
"cseTcamResourceUsed","4021.2","63","Gauge","1.3.6.1.4.1.9.9.97.1.9.1.1.3"
"cseTcamResourceUsed","4021.5","7","Gauge","1.3.6.1.4.1.9.9.97.1.9.1.1.3"
"cseTcamResourceUsed","4021.6","32","Gauge","1.3.6.1.4.1.9.9.97.1.9.1.1.3"
"cseTcamResourceUsed","4021.9","0","Gauge","1.3.6.1.4.1.9.9.97.1.9.1.1.3"
"cseTcamResourceUsed","4021.10","9","Gauge","1.3.6.1.4.1.9.9.97.1.9.1.1.3"
"cseTcamResourceUsed","5021.1","13","Gauge","1.3.6.1.4.1.9.9.97.1.9.1.1.3"
"cseTcamResourceUsed","5021.2","63","Gauge","1.3.6.1.4.1.9.9.97.1.9.1.1.3"
"cseTcamResourceUsed","5021.5","7","Gauge","1.3.6.1.4.1.9.9.97.1.9.1.1.3"
"cseTcamResourceUsed","5021.6","32","Gauge","1.3.6.1.4.1.9.9.97.1.9.1.1.3"
"cseTcamResourceUsed","5021.9","0","Gauge","1.3.6.1.4.1.9.9.97.1.9.1.1.3"
"cseTcamResourceUsed","5021.10","9","Gauge","1.3.6.1.4.1.9.9.97.1.9.1.1.3"
"cseTcamResourceUsed","7008.1","13","Gauge","1.3.6.1.4.1.9.9.97.1.9.1.1.3"
"cseTcamResourceUsed","7008.2","63","Gauge","1.3.6.1.4.1.9.9.97.1.9.1.1.3"
"cseTcamResourceUsed","7008.5","7","Gauge","1.3.6.1.4.1.9.9.97.1.9.1.1.3"
"cseTcamResourceUsed","7008.6","32","Gauge","1.3.6.1.4.1.9.9.97.1.9.1.1.3"
"cseTcamResourceUsed","7008.9","0","Gauge","1.3.6.1.4.1.9.9.97.1.9.1.1.3"
"cseTcamResourceUsed","7008.10","9","Gauge","1.3.6.1.4.1.9.9.97.1.9.1.1.3"
"cseTcamResourceUsed","8006.1","13","Gauge","1.3.6.1.4.1.9.9.97.1.9.1.1.3"
"cseTcamResourceUsed","8006.2","63","Gauge","1.3.6.1.4.1.9.9.97.1.9.1.1.3"
"cseTcamResourceUsed","8006.5","7","Gauge","1.3.6.1.4.1.9.9.97.1.9.1.1.3"
"cseTcamResourceUsed","8006.6","32","Gauge","1.3.6.1.4.1.9.9.97.1.9.1.1.3"
"cseTcamResourceUsed","8006.9","0","Gauge","1.3.6.1.4.1.9.9.97.1.9.1.1.3"
"cseTcamResourceUsed","8006.10","9","Gauge","1.3.6.1.4.1.9.9.97.1.9.1.1.3"
"cseTcamResourceUsed","9010.1","13","Gauge","1.3.6.1.4.1.9.9.97.1.9.1.1.3"
"cseTcamResourceUsed","9010.2","63","Gauge","1.3.6.1.4.1.9.9.97.1.9.1.1.3"
"cseTcamResourceUsed","9010.5","7","Gauge","1.3.6.1.4.1.9.9.97.1.9.1.1.3"
"cseTcamResourceUsed","9010.6","32","Gauge","1.3.6.1.4.1.9.9.97.1.9.1.1.3"
"cseTcamResourceUsed","9010.9","0","Gauge","1.3.6.1.4.1.9.9.97.1.9.1.1.3"
"cseTcamResourceUsed","9010.10","9","Gauge","1.3.6.1.4.1.9.9.97.1.9.1.1.3"
"cseTcamResourceTotal","4021.1","4096","Gauge","1.3.6.1.4.1.9.9.97.1.9.1.1.4"
"cseTcamResourceTotal","4021.2","32768","Gauge","1.3.6.1.4.1.9.9.97.1.9.1.1.4"
"cseTcamResourceTotal","4021.5","4096","Gauge","1.3.6.1.4.1.9.9.97.1.9.1.1.4"
"cseTcamResourceTotal","4021.6","32768","Gauge","1.3.6.1.4.1.9.9.97.1.9.1.1.4"
"cseTcamResourceTotal","4021.9","128","Gauge","1.3.6.1.4.1.9.9.97.1.9.1.1.4"
"cseTcamResourceTotal","4021.10","4096","Gauge","1.3.6.1.4.1.9.9.97.1.9.1.1.4"
"cseTcamResourceTotal","5021.1","4096","Gauge","1.3.6.1.4.1.9.9.97.1.9.1.1.4"
"cseTcamResourceTotal","5021.2","32768","Gauge","1.3.6.1.4.1.9.9.97.1.9.1.1.4"
"cseTcamResourceTotal","5021.5","4096","Gauge","1.3.6.1.4.1.9.9.97.1.9.1.1.4"
"cseTcamResourceTotal","5021.6","32768","Gauge","1.3.6.1.4.1.9.9.97.1.9.1.1.4"
"cseTcamResourceTotal","5021.9","128","Gauge","1.3.6.1.4.1.9.9.97.1.9.1.1.4"
"cseTcamResourceTotal","5021.10","4096","Gauge","1.3.6.1.4.1.9.9.97.1.9.1.1.4"
"cseTcamResourceTotal","7008.1","4096","Gauge","1.3.6.1.4.1.9.9.97.1.9.1.1.4"
"cseTcamResourceTotal","7008.2","32768","Gauge","1.3.6.1.4.1.9.9.97.1.9.1.1.4"
"cseTcamResourceTotal","7008.5","4096","Gauge","1.3.6.1.4.1.9.9.97.1.9.1.1.4"
"cseTcamResourceTotal","7008.6","32768","Gauge","1.3.6.1.4.1.9.9.97.1.9.1.1.4"
"cseTcamResourceTotal","7008.9","128","Gauge","1.3.6.1.4.1.9.9.97.1.9.1.1.4"
"cseTcamResourceTotal","7008.10","4096","Gauge","1.3.6.1.4.1.9.9.97.1.9.1.1.4"
"cseTcamResourceTotal","8006.1","4096","Gauge","1.3.6.1.4.1.9.9.97.1.9.1.1.4"
"cseTcamResourceTotal","8006.2","32768","Gauge","1.3.6.1.4.1.9.9.97.1.9.1.1.4"
"cseTcamResourceTotal","8006.5","4096","Gauge","1.3.6.1.4.1.9.9.97.1.9.1.1.4"
"cseTcamResourceTotal","8006.6","32768","Gauge","1.3.6.1.4.1.9.9.97.1.9.1.1.4"
"cseTcamResourceTotal","8006.9","128","Gauge","1.3.6.1.4.1.9.9.97.1.9.1.1.4"
"cseTcamResourceTotal","8006.10","4096","Gauge","1.3.6.1.4.1.9.9.97.1.9.1.1.4"
"cseTcamResourceTotal","9010.1","4096","Gauge","1.3.6.1.4.1.9.9.97.1.9.1.1.4"
"cseTcamResourceTotal","9010.2","32768","Gauge","1.3.6.1.4.1.9.9.97.1.9.1.1.4"
"cseTcamResourceTotal","9010.5","4096","Gauge","1.3.6.1.4.1.9.9.97.1.9.1.1.4"
"cseTcamResourceTotal","9010.6","32768","Gauge","1.3.6.1.4.1.9.9.97.1.9.1.1.4"
"cseTcamResourceTotal","9010.9","128","Gauge","1.3.6.1.4.1.9.9.97.1.9.1.1.4"
"cseTcamResourceTotal","9010.10","4096","Gauge","1.3.6.1.4.1.9.9.97.1.9.1.1.4"
Is there any relationship that can be gleaned from there to what I'm looking for?
rwill0ncgov
Can anyone verify that the mib:
CISCO-SWITCH-HARDWARE-CAPACITY-MIB
specifically,
CshcFibTcamUsageEntry ::= SEQUENCE {
        cshc72bitsFibTcamUsed   Unsigned32,
        cshc72bitsFibTcamTotal  Unsigned32,
will provide the values equivalent to:
It looks like this became available with 12.2(33) for C6500 sup720, and release 15 for 7600 - is that correct?
