Is it possible to run ssh on a VG202?
Yermander
Has anyone ever managed to enable ssh (v1 or 2) on a VG202? I need to do so as telnet being enabled on these devices is being flagged as a vulnerability on our network. I know I can use the Cisco feature navigator to see what features are available in an IOS image but is there a tool I could use to see what IOS images a platform is capable of running? TIA
Vinod Arya
What version of software are you running? You should be able to configure SSH on the VG devices which are running a crypto (*k9*) image.
To enable SSH on your device we need three things:
1.       Hostname
2.       IP domain-name
3.       Crypto rsa keys
You can enable rya keys using the command :
crypto key generate rsa general-keys modulus 1024
-Thanks
Vinod
**Encourage Contributors. RATE Them.**
-Thanks Vinod **Rating Encourages contributors, and its really free. **
