01-27-2017 02:41 AM
Supervisor 720 in 6509 switch is in Minfail mode. Can someone please help me find a solution for this? Should I reseat the module? Or should I replace it? It is running Version 12.2(18)SXF13. Show diagnostic module command does not work.
1 001e.4ab1.4da0 to 001e.4ab1.4db7 3.1 12.2(18r)S1 12.2(18)SXF1 MinFail
2 0025.84d8.ac98 to 0025.84d8.acc7 3.2 12.2(18r)S1 12.2(18)SXF1 Ok
3 0023.0455.b490 to 0023.0455.b497 1.6 12.2(18r)S1 12.2(18)SXF1 Ok
5 0019.e7d4.27f4 to 0019.e7d4.27f7 5.6 8.5(2) 12.2(18)SXF1 MinFail
Mod Sub-Module Model Serial Hw Status
1 Centralized Forwarding Card WS-F6700-CFC SAL114998HW 4.0 MinFail
2 Centralized Forwarding Card WS-F6700-CFC SAL1315N4S0 4.1 Ok
3 Distributed Forwarding Card WS-F6700-DFC3C SAL1250CY41 1.1 Ok
5 Policy Feature Card 3 WS-F6K-PFC3B SAL11488UDK 2.3 MinFail
5 MSFC3 Daughterboard WS-SUP720 SAL11488RV4 3.1 MinFail
Solved! Go to Solution.
01-27-2017 11:36 AM
Try checking the environment sensors (sh environment temp). Perhaps something has restricted airflow and is getting to hot. Yes I would also try re-seating the card. Can you leave it out of the chassis for 10 minutes (it case it is a temperature issue, so it can cool)?
01-27-2017 11:36 AM
02-07-2017 04:40 AM
Yes there was a A/C problem in the room. We did not have to re-seat the card - fixing the A/C resolved it. Thank you Philip.
