Support IP flow for WS-C3750-24TS-E
Erico Verissimo
Hello, good morning!
I have a cisco WS-C3750-24TS-E and I'm facing a problem to indentify the IP address which  higher spending the link. How can I monitoring the traffic flow on this device? Anyone can explain me please.
I tried to configure the ip flow but it doesn't support this feature apparently.
IOS c3750-ipservicesk9-mz.122-52.SE.bin
C3750 Software (C3750-IPSERVICESK9-M), Version 12.2(52)SE
Thanks in advanced!
Marvin Rhoads
The only type of Catalyst 3750 that supports Netflow is the 3750-X with an optional C3KX-SM-10G.
The older 3750 types such as yours do not support Netflow at all.
Generally speaking for Cisco devices, Netflow is best gathered from a router, second choice firewall and (distant) third choice a layer 3 switch.
Even for those switches that support it, it is (again - generally speaking) not very well-supported. There are a few exceptions, but not many.
6 Replies 6
Marvin Rhoads
Thank you Marvin!
If I upgrade the IOS in this version, is it possible get at less the flexible Netflow?
No. It's a hardware limitation on the model you have.
The Service Module I mentioned earlier for the 3750-X includes ASICs that remedy that fact (when used with the requisite IOS level).
Thank you for this information. I will need to change this router for other which support Netflow.
Youre welcome. Please mark your question as answered if it has been.
