SUPPORTED DEVICE FOR MINI-RMON ON CISCOVIEW
vaibhav-g
Hi Team
plse let us know any document containing supported devices for CISCO VIEW MINI-RMON MANAGER.
ALSO HOW WE CAN CONFIGURE THE SAME ON LMS.
Vaibhav
frankzehrer
Level 4
Level 4
Hi Vaibhav,
just use the LMS Help.
How to configure:
Navigate to the Application in CiscoWorks and then click on the Link "Help" on the upper right corner of your browser.
Supported Devices:
Within the above opened Help Window click on the "Search" tab in the left pane and search for "Supported OIDs".
Be sure that the dearch options are "All Words" and "miniRMON"
Hope that helps a bit.
Best regards,
Frank
Hi Frank
In help i am able to see only SWITCHES,could you let us know the supported routers on it.
how we can enter MIB or OIDS in CISCO VIEW.
what are the MIBS and OIDS for router
also let us know the full command to ener in router.
Vaibhav
