Switch configuration
vinoth.kumar
We had a plan to purchase a switch and a router but can you suggest me some switch and a router which as a following feature
For Switch :
1. Chasis comuntator feature level in L3 and L4
2.Speed Commutation higher than 60 Gbps
3.80 ports 10/100 Mbps fast ethernet minimum
4.port POE 10/100 fast ethernet
5.Ports 10/100/1000 mbps gigaethernet Administration tool needs to be supplied and installed
6.Management module
7.redundant power supply
8.support routing level3
9.management snmp, rmon, smon
10.modul extractible a chaud
11.spanning tree
12.full and half duplex on the ports 10/100TX and 1000 base tx.
13.security et filtering on mac level by address ip et crypting of data
14.management of priorities, of traffic(802.1p)
15.Rackable 19''
For Router:
1.MODULAR
2.1 PORT 10/100 MBPS
3.1 PORT SYNCHRONE
4.1 PORT AUXILIAIRE ET UN PORT AUXILIAIRE
5.SLOTS sic ET 1 SLOT mim
6.PROCESSEUR/ 80 kBPS
7.M2MOIRE ROM/ 512kB
8.SDRAM /256 mB
9.CABLES ET CONNECTRIQUE NECESSAIRES
It would be very helpful if we get the compatiable switch and router with the above features
Vinoth
ebreniz
Level 6
Level 6
You can go for Cisco Catalyst 6500 Series Switches and for more information please click following URL:
http://www.cisco.com/en/US/products/hw/switches/index.html
Cisco 3800 Series Integrated Services Routers
Cisco 3700 Series Multiservice Access Routers
Cisco 3600 Series Multiservice Platforms
http://www.cisco.com/en/US/products/hw/routers/index.html
