Switch management tool
Moudar
Hi!
I was looking for a tool that can be used to manage many switches at the same time. By manage i mean:
-having a list of all my switches in one place
-the ability to login to cli using ssh without the need to write my login details
-take back ups of the running config, and much more
Prime can manage but it lack the ability to login med ssh! or do i miss something?
we dont have DNA yet, don't know if DNA have this ability
We have used Winagents Hyperconf, and now we need to find something better and have maybe the same abilities or better!
Any suggestions?
7 Replies 7
balaji.bandi
before it was network assistance now no Longer available, need to use any 3rd party tools
BB
Leo Laohoo
@Moudar wrote:
and much more
AKIPS
I have never heard about AKIPS!
How good is it?
@Moudar wrote:
How good is it?
I have been using AKIPS since 2018 and we have AKIPS, PI and DNAC running in parallel.
AKIPS is bang-for-your-bucks.  Hands down.
depending on whether your switches support RESTCONFIG, you could use that in combination with the POSTMAN GUI.
Is it possible to use Postman the same way as Hyperconf? I mean switch list and backups..?
We have many 9200 switches
Postman is the front end GUI for RESTCONF. It let's you do device listings, backups, and much more...
Here is a good link:
https://algoderedes.com/en/restconf-operations/
