Switch management
shansfeldt
Frequent Visitor
Frequent Visitor
I need to configure read-only user to a Cisco 2960 switch. They want to see the config.
How can I hide enable password in config from the read-only users.
The encrypted password is not enough.
5 Replies 5
Joe Clarke
What version of code is running on the switch?
The version is :
(C2960-LANBASEK9-M), Version 12.2(50)SE
Cisco 2960-24TT-L
Best Regards
Magnus
You can use the Embedded Event Manager to post-process the configuration, and filter out passwords. I actually had another user ask for this, so I developed this Tcl policy to filter out passwords and community strings. Of course, to actually limit them to certain commands (i.e. prevent them from entering config t mode, you would need to use other policies, or AAA command authorization).
To register this EEM policy, create a directory on flash like flash:/policies. Copy the script into this directory. Then configure:
event manager directory user policy flash:/policies
event manager policy cl_show_run.tcl
Now execute "show running-config". You'll notice the password fields are missing. Now execute "write term". You'll see the passwords show up. So, in AAA, limit your read-only user to only being able to run "show run", and they will not be able to see passwords.
Leo Laohoo
DO a "sh tech" and cut out the bottom bit.
No, the users want to login to the switch as read-only and then run "sh config".
They want to see the config, but I don't want them to see the password, even if it is encrypted.
If I do a config like below, they can do a show tech-support.
The problem here is that the config is not there.
aaa new-model
username xxxx privilege 2 password xxxx
aaa authorization exec default local
privilege exec level 2 sh tech
Thanks for your time!
Best Regards
Magnus
