Switch PBR working is not normal.
eeebbunee
Level 5
Level 5
Hello Professionals,
I have unexpected issue when applying PBR with my Cisco switch, but don't understand why this happened.
First things First,
   - Switch: C9300L-48P-4G-E
   - Version: 16.12.4
   - Image: CAT9K_IOSXE
I have PBR policy and it applied to 2 different VLANs.
interface Vlan111
description Default
ip address 10.111.0.1 255.255.255.0
ip policy route-map SVN_Project_R
interface Vlan222
description SVN Project Users
ip address 10.222.0.1 255.255.255.0
ip access-list extended SVN_Project
10 permit ip 10.111.0.128 0.0.0.15 host 172.21.100.100
20 permit ip host 10.222.0.10 host 172.21.100.100
route-map SVN_Project_R permit 10
match ip address SVN_Project
set ip next-hop 10.333.0.254
So, my configuration working fine so far.
However when tried to delete configuration like this>>
  BB(Config)# no ip access-list extended SVN_Project
All networking is stopped. It looks like switch no longer routing.
I thought even though I delete the PBR ACL, routing works fine cause switch has last resort as a gateway.
I would like to make sure routing was messed because I just deleted ACL or switch works weird way.
Please help.. much appreciated.
11 Replies 11
IP_Cartel
Level 6
Level 6
do you have an ip policy route-map SVN_Project_R permit 10 on the interface?  This is the correct name of the route map? SVN_Project_R permit 10
Yes that is configured like that.
I'm not sure the differences between
Route-map SVN_Project_R permit 10
And
Should I change configuration to 'Route-map SVN_Project_R'?
Thank you very much for your comment!
You are right the SW can use RIB to routing the traffic if route-map (PBR) is delete BUT
are you config any default route in SW to make SW use it to forward packet after you delete PBR ??
if NO, then you need to config default route
Hello @MHM Cisco World
Default route means the configuration has 'ip route 0.0.0.0 0.0.0.0 next hop'?
When I do >> sh ip route
Gateway of last resort is 10.333.0.254 to network 0.0.0.0
Please advise me if that isn't that enough to have default route..
Thank you very much..!
Yes I think so,
you need default route as you mention above.
friend you are right, @Georg Pauwen mention using debug ip policy to notice the behave of PBR with empty ACL and as you notice
the traffic still mark as match and use next-hop set in PBR even after I config static route and ip default-gateway.
so it not normal
I am not clear about "so it not normal ". What is not normal?
The behavior of an empty (or non existent) acl has changed over time. In early versions of IOS a reference to an empty/non existent acl would use the implicit deny all. Then the behavior changed. For a long time the normal behavior of reference to an empty/non existent acl is permit any.
I agree that the way to really settle this question is to run debug for PBR. I predict that it will show that all traffic is using the special PBR forwarding and not the normal forwarding.
Rick
I found this in cisco doc. which can explain the behave of empty ACL.
""If no ACL is configured in order to establish the match criteria, it results in all traffic being policy-routed.""
Thank you. That reference does confirm my explanation of what is going on.
Rick
Georg Pauwen
with the access list removed, turn on 'debug ip policy' and post the output.
Am I correct in understanding that the ip policy route-map is still applied on both vlan interfaces and that the route map is still in the configuration, and only the acl has been deleted? I believe that the behavior of the route map is that if there is a match statement pointing to an acl but that acl does not exist then effectively there is no match statement logic in the policy. The result is that all traffic now matches the route map and is being forwarded to 10.333.0.254.
If you delete the acl used by PBR then why would you retain the route map and the ip policy statements?
I believe that if you remove the ip policy route-map statement from both vlan interfaces then your routing will return to normal.
Rick
