11-23-2007 12:35 AM
On Campus Manager, topology view, the routers are displayed disconnected from the switches, why don't i see the link between the switches and router?
Thank You for your time and assistance,
Genet .
11-23-2007 12:47 AM
Hi Genet,
what Version of CM you are uning?
Do you have CDP enabled on the devices?
Best regards,
Frank
11-23-2007 12:54 AM
Thank You very much, frank. I am using CM ver4 and yes have enabled cdp.
Thank You again!
Genet T.
11-23-2007 12:57 AM
Hi Genet,
what subversin? You need to be more specific.
4.0.0 or 4.0.3 or 4.0.9?
Frank
11-23-2007 01:04 AM
Hi Frank,
It is 4.0.3
Genet
11-23-2007 01:11 AM
Hi Genet,
therefore i assume you are running LMS 2.5.1.
There were issues like that in the older CM Versions on the 2.5.x train and should now be fixed.
You should obtain the free Upgrade to LMS 2.6 and then upgrade to CM 4.0.9.
Best regards,
Frank
11-23-2007 03:47 AM
Hi Frank,
True i am running LMS 2.5
I will upgrade both and check the outcome.
Thank You so much for your time and Help.
kind Regards,
Genet
