07-23-2021 01:33 PM
Hi all,
I am switching my Static ip address to Dynamic ip address. what is the procedure to that using CLI on my ASA 5506-x
Below is my configurations.....Thank you!!
interface GigabitEthernet1/1
nameif outside
security-level 0
ip address 10.0.0.1 255.255.255.0
no shut
interface GigabitEthernet1/2
nameif inside
security-level 100
ip address 192.168.10.254 255.255.255.0
no shut
interface GigabitEthernet1/3
nameif camera
security-level 95
ip address 192.168.20.254 255.255.255.0
no shut
interface GigabitEthernet1/4
nameif security
security-level 90
ip address 192.168.30.254 255.255.255.0
no shut
interface GigabitEthernet1/5
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet1/6
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet1/7
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet1/8
shutdown
no nameif
no security-level
no ip address
interface Management1/1
management-only
shutdown
no nameif
no security-level
no ip address
ftp mode passive
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object network obj_any
subnet 0.0.0.0 0.0.0.0
access-list OUTSIDE_ACCESS_IN extended permit icmp any any echo
access-list OUTSIDE_ACCESS_IN extended permit icmp any any echo-reply
pager lines 24
logging enable
logging buffered informational
mtu outside 1500
mtu inside 1500
mtu camera 1500
mtu security 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-782.bin
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
arp rate-limit 16384
nat (any,outside) dynamic interface
access-group OUTSIDE_ACCESS_IN in interface outside
route outside 0.0.0.0 0.0.0.0 10.0.0.1 1
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 sctp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
timeout conn-holddown 0:00:15
timeout igp stale-route 0:01:10
user-identity default-domain LOCAL
aaa authentication ssh console LOCAL
aaa authentication http console LOCAL
aaa authentication login-history
http server enable
http 0.0.0.0 0.0.0.0 inside
no snmp-server location
no snmp-server contact
service sw-reset-button
crypto ipsec security-association pmtu-aging infinite
crypto ca trustpool policy
telnet timeout 5
ssh stricthostkeycheck
ssh 0.0.0.0 0.0.0.0 inside
ssh timeout 60
ssh key-exchange group dh-group1-sha1
console timeout 0
management-access inside
dhcpd dns 8.8.8.8 8.8.4.4
dhcpd address 192.168.10.10-192.168.10.100 inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
dynamic-access-policy-record DfltAccessPolicy
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns migrated_dns_map_1
parameters
message-length maximum client auto
message-length maximum 512
no tcp-inspection
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect ip-options
inspect netbios
inspect rsh
inspect rtsp
inspect skinny
inspect esmtp
inspect sqlnet
inspect sunrpc
inspect tftp
inspect sip
inspect xdmcp
policy-map type inspect dns migrated_dns_map_2
parameters
no tcp-inspection
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
call-home
profile CiscoTAC-1
no active
destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
destination address email callhome@cisco.com
destination transport-method http
subscribe-to-alert-group diagnostic
subscribe-to-alert-group environment
subscribe-to-alert-group inventory periodic monthly
subscribe-to-alert-group configuration periodic monthly
subscribe-to-alert-group telemetry periodic daily
To enable ASDM on Cisco ASA, the HTTPS server needs to be enabled, and allow HTTPS connections to the ASA.
To configure ASDM (HTTP) access to Cisco ASA on particular interfaces, where core and management are the nameifs use following commands:
ASA(config)#aaa authentication http console LOCAL
ASA(config)#http server enable
ASA(config)#http 0.0.0.0 0.0.0.0 core
Remember to create username, password to be able to authenticate to asdm:
ASA(config)#username admin password secretpassword
07-23-2021 04:18 PM
nameif outside
security-level0
ip address dhcp setroute
any static route added remove from config.
07-23-2021 08:04 PM
07-24-2021 02:11 AM
It gets the IP address from the DHCP server and adds the route also. (i would suggest to shut down the port and configure this on ASA, and bring up, if any device it was connected to before, there may be ARP entry, depends on ARP time out it will clear, so you can do manually clear that ARP before you bring up ASA Interface ).
07-24-2021 10:13 AM
The other thing that you should do is to change/remove the existing static default route
I note that the next hop specified here is actually the configured IP address of the ASA itself.
07-24-2021 12:23 PM
So what I understood from both you and thank you both you.
All I need to change are below with different font and should work?
1- interface GigabitEthernet1/1
nameif outside
security-level 0
no shut
2- route outside 0.0.0.0 0.0.0.0 10.0.0.1 1
Thank you,
Ammar
07-25-2021 01:09 AM
Ammar
Yes those are the 2 things you need to change.
07-25-2021 04:16 AM
07-25-2021 12:10 PM
Ammar
You are welcome. This community is an excellent place to ask questions and to learn about networking. I hope to see you continue to be active in the community.
08-03-2021 06:44 PM
Hi Richard,
I have the ASA 5506-x hooked it to the G3100 Verizon router as outside 192.168.1.254 and it’s working fine.
But what I want to do, is eliminate the Verizon router and connect the ethernet from the ONT directly to the ASA using dynamic IP address provided from Verizon.
It is not working that way .
Below is my config:
nameif outside
security-level 0
ip address 10.0.0.2 255.255.255.0
Do I need to do something else?
Thank you,
Ammar
08-04-2021 02:26 AM
interface GigabitEthernet1/1 nameif outside security-level 0 ip address 10.0.0.2 255.255.255.0 !
G3100 Verizon router - is the same IP address configured on this router ? if then above config should work for you.
test from ASA are you able to ping 10.0.0.1 first ? and able to reach 8.8.8.8 from ASA, before going inside.
Hope your internal IP address do not overlap with 10.x.x.x. range
08-04-2021 07:53 AM
Ammar has clarified what he wants to accomplish "But what I want to do, is eliminate the Verizon router and connect the ethernet from the ONT directly to the ASA using dynamic IP address". @balaji.bandi has supplied very good suggestions about the changes to make. Ammar says it does not work and supplies the config but it looks like the original config and not the changes that were suggested.
If the changes are made and it is not working then we need to look further for issues. Perhaps as a starting point you could post the content of the routing table for the ASA and the content of the arp table.
08-05-2021 04:00 AM
Hi all,
Below the config I have right now and its working fine. which is I have the verizon route before the ASA. but when I configure the dynamic ip address as an outside in ASA, which is taking Verizon router out the picture won't work. why? maybe because it is a dynamic ip not static. before it was configured with static ip and the ONT was connected directly to the ASA but that time i had static ip from Verizon, now i have dynamic ip..
nameif outside
security-level 0
ip address 192.168.1.254 255.255.255.0
nameif inside
security-level 100
nameif camera
security-level 95
nameif security
security-level 90
shutdown
no nameif
no security-level
no ip address
shutdown
no nameif
no security-level
no ip address
shutdown
no nameif
no security-level
no ip address
shutdown
no nameif
no security-level
no ip address
management-only
shutdown
no nameif
no security-level
no ip address
ftp mode passive
dns server-group DefaultDNS
domain-name no
pager lines 24
logging enable
mtu outside 1500
mtu inside 1500
mtu camera 1500
mtu security 1500
arp timeout 14400
route outside 0.0.0.0 0.0.0.0 192.168.1.1 1
http server enable
telnet timeout 5
ssh timeout 60
console timeout 0
dhcpd enable inside
parameters
no tcp-inspection
inspect ftp
inspect h323 h225
inspect h323 ras
inspect ip-options
inspect netbios
inspect rsh
inspect rtsp
inspect skinny
inspect esmtp
inspect sqlnet
inspect sunrpc
inspect tftp
inspect sip
inspect xdmcp
parameters
no tcp-inspection
call-home
profile CiscoTAC-1
no active
Cryptochecksum:dd7a7017b7bd90d70a704f5bf1a49a9e
: end
08-05-2021 06:26 AM
The basic question still stand the same. we all know this config working, when you connect back to verizon router. and varizon router have 192.168.1.X network IP address.
The questions not addressed :
1. is the verizon support with ASA as client directly ?
2. when you make outside interface as DHCP, did you get IP address from ISP ?
3. some ISP do not like Static IP to configure, they get authenticated and allocate the IP (this is not happening your case i guess)
08-05-2021 08:34 AM
I am confused about this statement " before it was configured with static ip and the ONT was connected directly to the ASA but that time i had static ip from Verizon". Am I understanding correctly that at one time the ASA was connected directly to the ONT, using a static IP, and things worked correctly? If that is the case it might explain why attempting to connect with a dynamic IP is having problems. If the ONT is expecting a static IP it may not support having a dynamic IP.
Showing us the running config where the ASA has a static IP and is connected to Verizon is not very helpful. If the intent is to have the ASA connect to the ONT with a dynamic IP then what we need to see are results when the ASA is connected to the ONT and the configuration running at that time. The question from @balaji.bandi about whether the ASA get an address from ONT is an important question. And I would repeat my request that in that new environment we see the content of the routing table and of the arp table.
