Syslog does not forward Messages to RME
mgatterer
Hello together,
I have a problem for a specific Device (Cisco Aironet 350) and RME.
I send syslog Messages to the CW Syslog Collector. I recieve the Messages with correct timestamp and correct format in the "syslog.log" file on the server but when i go to the "Device Center Home" of the Device or any Syslog-Report - I do not see any entry for this Device.
For other Devices all works fine.
I use LMS2.5 with all latest patches installed.
I hope, someone can help me.
Best regards
Mario
nhabib
Level 9
Level 9
Is Syslog working for other devices?
Are the AP's running IOS or the old VxWorks?
nhabib
Level 9
Level 9
Thanks for your Answer.
The Access Points are all running IOS - The 350 with the Upgrade-Image.
But i solved the Problem by myself.
-> Put the AP out of CiscoManagement (Delete in Device List) and let him descover new by Campus. Now all works fine. (Perhaps bad sync beetween Syslog and RME ??)
Best Regards
Mario
