Syslog filter with tcl commands
974312magr
Hi.
I was checking the tcl function ( http://www.cisco.com/en/US/partner/products/sw/iosswrel/ps5207/products_feature_guide09186a00801a8516.html#wp1063029 ) in IOS routers because I want filter all IPS events sending to a CiscoWorks Syslog collector, but I have a problem.
I introduced a script using the tclsh command, but it filtered all the syslogs events. I want to entered an other script, but I can´t delete the first one. I reload the device, but the first one script is still worked.
Could someone tell me how can I delete the first script? Where the script is stored when you introduced it with cli commands?
Besides, someone has an example of the script filtering events containing a specific facility or containing determined word in the mnemonic?
Thanks.
Marco.
b.hsu
Level 5
Level 5
take a look at the following documents:
Cisco IOS Scripting with Tcl -
http://www.cisco.com/univercd/cc/td/doc/product/software/ios123/123newft/123
t/123t_2/gt_tcl.htm
Embedded Syslog Manager -
