06-17-2011 04:36 AM
Hello.
I have installed LMS 4.1 on our server. Now it has worked fine for almost a month, but now I have a strange problem.
At the top of the page indicates the number of program errors or syslog. The problem is that the number is constant and does not change. If I click on the numbers, I get an error message (see attachment)
I have done as described in the document https://supportforums.cisco.com/docs/DOC-8796, but with the exception of the password.
But the problem is still there. Some suggestions on what I can try now?
I am running LMS 4.1 on a Windows 2008 - R2 and has 1500 licenses
Jens Arne Skage
Bergen / Norway
06-18-2011 10:41 AM
What browser are you using? Firefox 4.0 is known to not work with the Fault Monitor view. You will need to use IE 7.0, IE 8.0, or FF 3.6.
06-19-2011 09:57 PM
Hello again and thanks for your response.
We use IE 8 (see Appendix). I have tested on both Windows 7 and XP, but with the same result.
Can errors with IE also caused the error message "Sorry, an error occured" in the Monitor> Monitoring Tools> Fault Monitor (See Appendix), I also see that the process DFMCTMStartup is in status "Administrator ha shut down this server" is this normal?
Regards Jens
06-25-2011 10:56 AM
The only other issue I know around the Fault Monitor is CSCtf53724, but the workaround is simply to reload the screen. Are you able to test another browser (either Firefox 3.6 or IE 7)? I also noticed your client is localized for Norwegian. Try a US English localization.
The DFMCTMStartup daemon is almost always shutdown under normal circumstances. This is not causing a problem.
