System Source Address
dnewell24
Level 5
Level 5
Is it possible to set the source address for all mgmt packets generated by the router ie. snmp, syslog, ntp, TACACS+. I know of the command for snmp and syslog..
Syslog = logging source-interface "interface"
SNMP = snmp-server trap-source "interface"
Is there one command for all protocls? If not is there a command for NTP and TACACS+?
Ryan
m.sir
Level 11
Level 11
yes you can
router(config)#ip tacacs source-interface
and
router(config)#ntp source
M.
Hope that helps rate if it does
m.sir
Level 11
Level 11
yes you can
and
M.
Thank you sir!
