TACACS-3-L3VM_SDB_READ
peterchon
Hi, my several n7ks are repeating %TACACS-3-L3VM_SDB_READ message and it fills out my syslog. Someone tells me this is due to bug but I cannot find any info.
Any one has same issue or solution can share?
Syslog msessages;
%TACACS-3-L3VM_SDB_READ: Error reading context id         1, errno: 0x40480008 (bad pss service handle) in l3vm_get_context_info()
last message repeated 2 times
thanks,
Hi ,
unfortunately your IOS code is affected:
Known Affected Releases:
6.0(1)
Thanks-
Afroz
[Do rate the useful post]
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
AFROJ AHMAD
This is the BUG Id:
Nexus- %TACACS-3-L3VM_SDB_READ: Error reading context id
CSCub45904
Known Fixed release:
6.1(1.71)S0
5.2(8.9)S0
6.2(0.285)
6.1(2)
5.2(9)
6.1(4.1)S0
6.0(2)ZD(0.6)
6.0(2)U2(1)
6.2(2)
No workaround..
by the way what is the IOS code your device is running ?
Thanks-
Afroz
Thx, I am running 6.0(1)
Hi ,
6.0(1)
Thanks-
Afroz
