Tacacs / AAA not working in WS-C3850-48P Switch
pgyogeshkumar
Hi..
I am facing issue in WS-C3850-48P switch for inband connectivity when I enable AAA in the switch with tacacs authentication as its not working at all.
Is theer any bug with this switch or the software we using?
Software Used : cat3k_caa-universalk9.SPA.03.06.03.E.152-2.E3.bin
Please let us know if its software issue or tell us how to make it working please.
Config wise no issues and we use the same template for other IOS devices for AAA. Need your help to get this resolved,
Mark Malone
that's a dodgy image anyway , 3.6.6 is the recommended image , anything on 3.3 and below was littered with bugs , if its working on other switches same config change the ios is the next step ,you can check your release notes but aaa and tacacs work fine on 3.6.6 I have bundles of ios-xe switches on it ,cant suggest anything else as no config shown to see if somethings a miss ,
