Tacacs login prompt
N W
Hi Guys
Is there a way to change your login prompt when you are using Tacacs?
Using local database I got a
Usename:      prompt
with tacacs I get
Login:           prompt
I know I can change the username prompt for the local, but can I change it for Tacacs?
This is play havoc with Cattools thats looking for a username prompt and wont access a login prompt
N W
Ignore
sortted it out myself
