TCL: Best way to store Variables between TCL script run times?
tproeber
If I am simply running a TCL script every 10 seconds, how can I store varilable info between the TCL script runnings?
I have tried:
+ Writing the info to an EEM Variable in the Sho-Run, and then reading in this info each time the script runs, and then writing the changes to the EEM Variable before exiting
    -- this works, but the available storage space is short and makes the sho-run looks "bad" for non=TCL types
+  Writing and reading the variable info to Flash: files.
   --  this works too, but a Flash has only so many writes and then when that limit is reached . . .it boots in RMON
Q: Can I do this?
Disclaimer:  I am not a REAL programmer, but a scripter . . .
Tim
CCNP - Security
CCNP - Wireless
Joe Clarke
If you're using EEM, you can use a system called contexts to save data in memory between executions.  Here is some example code:
# Retrieve any previous context data
if { [catch {context_retrieve MYCTXT myvar} result] } {
    set myvar 0
} else {
    set myvar $result
# Save the variable for the next run
catch {context_save MYCTXT myvar}
You can even save arrays like this:
if { [catch {context_retrieve MYCTXT myarr} result] } {
    array set myarr [list]
} else {
    array set myarr $result
catch {context_save MYCTXT myarr}
