Tcl Format Question
Hello Community,
Can someone please tell me if the following format would work:
foreach tag [list "SLA1_Towerbridge_10.1.1.4"_
"SLA2_LondonBridge_180.80.8.4"_
"SLA3_Paddington_170.70.7.4"_
"SLA4_150.50.5.2"_
"SLA5_160.60.6.1"] {
    if { [info exists mar_einfo($tag)] } {
        break
I'm trying to shorten the length of line of code by adding a carriage return, instead of having to do the following:
foreach tag [list "SLA1_Towerbridge_10.1.1.4" "SLA2_LondonBridge_180.80.8.4" "SLA3_Paddington_170.70.7.4" "SLA4_150.50.5.2" SLA5_160.60.6.1"] {
        break
Cheers
Carlton
Joe Clarke
You need to use a '\' character to break up lines:
foreach tag [list "SLA1_Towerbridge_10.1.1.4" \
"SLA2_LondonBridge_180.80.8.4" "SLA3_Paddington_170.70.7.4""SLA4_150.50.5.2" SLA5_160.60.6.1"] {
